Image Frame Issues
Image Frame Issues
c_hornyak
Message 1 of 18
Image Frame Issues
c_hornyak
I have an image of the company logo XREF'd into our titleblocks. I have the IMAGEFRAME setting set to "2" in all my template drawings. The frame of the image still plots a lot, even if the IMAGEFRAME setting is set to "2" still. What normally fixes it is changing the setting to "1" and then changing back to "2". Is there anything I should try so I don't have to constantly check if it plotted on my sheets? Thanks.
Replies (17)
Message 2 of 18
paullimapa
Make sure you’ve installed the latest AutoCAD updates for your version. Enter About command do a screenshot and share that here
Paul Li
IT Specialist
@The Office
Message 3 of 18
cjneper
Does Imageframe = 0 work?  I use that setting with no issues.
Message 4 of 18
pendean
Community Legend
Community Legend
Message 5 of 18
c_hornyak
@paullimapa , when I run the about command, it says I have product version T.53.0.0 AutoCAD 2023
Message 6 of 18
paullimapa
T181 is the latest so you should sign in to your account and update
https://help.autodesk.com/view/ACD/2023/ENU/?guid=AUTOCAD_2023_UPDATES
Paul Li
IT Specialist
@The Office
Message 7 of 18
c_hornyak
@paullimapa , now I have version U.152.0.0 AutoCAD 2024 so I will see if this fixes it.
Edit: it didn't, I found a drawing of mine that has the IMAGEFRAME set to 2 already and the frame is still plotting
Message 8 of 18
paullimapa
Now what if you change imageframe to 0 and plot just to make sure the frame doesn’t show up. Then change it back to 2 and plot again to see if it stops showing the frame then.
Paul Li
IT Specialist
@The Office
Message 9 of 18
c_hornyak
I just tried that on a drawing. I opened the drawing and IMAGEFRAME was set to 2. I then tried changing it to 0 and it still plotted. Then I changed it back to 2 and it still plotted.
Message 10 of 18
paullimapa
With imageframe set to 0 it should not plot...something is definitely wrong here.
If you can share your drawing.
Paul Li
IT Specialist
@The Office
Message 11 of 18
pendean
Community Legend
Community Legend
Start here https://forums.autodesk.com/t5/autocad-forum/imageframe-issues/m-p/7927629#M928985
Message 12 of 18
cadffm
is it really a rasterimage object? not OLE
what file format?
- and another image for a test,  same issue?
- if the image is attached directly into the file, same issue?
- is it the same in layout AND model tab?
For usual (another dwg and another image) it works well?
>" I found a drawing of mine that has the IMAGEFRAME set to 2 already and the frame is still plotting"
Without your cad-data (dwg&imagefile) we can guess a lot.
For example:
It isn't the image frame, it is part of the image
 or
It isn't the image frame, it is an OLE the the oleframe
 or
it is a problem with the backgroundtransparency property with this imagereference
 and more
Sebastian
Message 13 of 18
cjneper
When you set imageframe = 0 can you see the frame disappear on screen?  If not it might be part of the image, not the frame.  You should be able to see the frame toggle on and off as you change that variable.
Message 14 of 18
c_hornyak
Sorry for the slow response, I had to wait until I found another file with the issue. This file I had the IMAGEFRAME set to 2 but it still plotted. The logo in the top right corner is what I am having issues with.
@cadffm, this file was using my old setup where the logo is a PDF. On all my new projects, the logo is a jpg. I also have an etransmit attached that shows my new setup with the jpg.
Message 15 of 18
pendean
Community Legend
Community Legend
Set FRAME system variable to 2 and call it a day
https://help.autodesk.com/view/ACD/2024/ENU/?guid=GUID-29BD70BB-07BF-41A2-8C2F-AD41C9402486
Message 16 of 18
c_hornyak
You can not set the value of frame manually
Message 17 of 18
pendean
Community Legend
Community Legend
Why not? I did in both of your separate files.
Message 18 of 18
c_hornyak
I ended up resolving this just by resizing the image to fit perfectly in the titleblock were I need it so it doesn't matter if the frame is showing or not any more. It is not a real solution, but for my purposes, it is good enough.
