hi there, im using VBA for AutoCAD and everything was fine but there's a major problem, everytime i ran my program all the lines showed up but the numbers keep rounding. For example when it's supposed to be 2,87 meters, it become 2 meters, or when it's supposed to be 3,1 meters, it become 3 meters.
I already change my units setting with decimals and 0.00000 precision but it doesnt change anything. Any help?
Since 2,87 is displayed as 2 and not 3 I would guess the data type for the variable is Integer or Long and should be Double. If 2,87 became 3 then it would indicate a rounding to zero decimal places.
already changed it, result still the same. i tried to open the file in another laptop and it showed the correct number.
is the problem comes from my laptop?
This is very difficult to debug without the program and a sample file highlighting the problem.
