AutoCAD Forum
if then else formula in a field or case then formula in a field
5 REPLIES 5
Jacques_V_
544 Views, 5 Replies
Jacques_V_
Please we need the official Documentation about using formulas inside fields.
We have a field with page numbering, a Layer XX of YY Field. Render is "Page 01/50", "Page 02/50", ...
So we need Documentation and Examples about $if(condition,"case_1","case_2"), please.
Our Layer Tabs are named F-A3, F-A3 (2), F-A3 (3), etc. because in our Template we have only 1 layer, nammed F-A3 then we copy each layer to print further the drawing.
$(strlen,$(getvar,ctab)            Works shows length of string of current tab name
$(strlen,$(getvar,ctab),8)       Works shows length of string of current tab name, with useless parameter "8"
$(substr,$(getvar, ctab),7,1)   Works shows 1 caracter beginning at 7th caracter in current tab name
$(substr,$(getvar, ctab),7,2)   Works shows 2 caracters beginning at 7th caracter in current tab name
$(if,$(=,$(strlen,$(getvar,ctab),4),"case_1","case_2"))      X Doesn't work Should show "case_1" if current tab name length is "4" or else should show "case_2"
$(if,$(<,$(strlen,$(getvar,ctab),9),"case_1","case_2"))      X Doesn't work Should show "case_1" if current tab name length is less than "9" or else should show "case_2"
$(if,$(<,$(strlen,$(getvar,ctab),9),$(substr,$(getvar, ctab),7,1),$(substr,$(getvar, ctab),7,2)))           X Doesn't work Should show "1 caracter beginning at 7th caracter in current tab name" if current tab name length is less than "9" or else should show " 2 caracters beginning at 7th caracter in current tab name" . Example "2" out of "F-A3 (2)" else "12" out of "F-A3 (12)".
Finaly it would be nice to get total number of layer tabs (total number of pages) "Page $current tab/$count of tabs"). Currently we created a custom Total Count of Layers Property in Template then we mannually update it in each drawing.
Regards
https://forums.autodesk.com/t5/image/serverpage/image-id/353923i104F2C57C37AC57C/image-size/small?v=v2&px=200https://forums.autodesk.com/t5/image/serverpage/image-id/353923i104F2C57C37AC57C/image-size/small?v=v2&px=200
Regards
Tags (1)
Labels (1)
5 REPLIES 5
cadffm
in reply to: Jacques_V_
cadffm
this is DIESEL and has nothing to do wie fields (but you can use it in Diesel-fields, of course).
DIESEL is documented [F1] , well enough for this basic stuff (just a help documentation. Not a tutorial)
Variable for total layouts and also current layout in order would be good, i am with you.
Sebastian
Sebastian
paullimapa
paullimapa
To get layout numbers as a field but using lisp the following thread may be of interest to you:
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/page-numbering-for-layouts-using-fie...
Paul Li
IT Specialist
@The Office
Paul Li
IT Specialist
@The Office
pendean
pendean
Community Legend
Community Legend
@Jacques_V_ wrote:
Please we need the official Documentation about using formulas inside fields....
FIELD command is covered in AutoCAD's HELP, I'll get you started with the online HELP version here
https://help.autodesk.com/view/ACD/2024/ENU/?guid=GUID-742C92C3-1284-4722-B650-C46F9191C701#:~:text=...
DIESEL is what you are using and posting about though, which can be used in FIELDs and MTEXT and block ATTRIBUTES too. AutoCAD's HELP guidance is a good place to start, I'll help you out with an online link too, it starts here
https://help.autodesk.com/view/ACD/2024/ENU/?guid=GUID-76B3F3D3-6B9A-43E7-BE2C-D4B39AC3FBCF
HTH
HTH
Jacques_V_
Jacques_V_
Thank you all for your help.
So the direct link is :
https://help.autodesk.com/view/ACD/2024/ENU/?guid=GUID-F94A885A-4DA2-432B-AC1A-EB49CC6C1C72
An alternative link, with some minor differences is :
https://www.fourmilab.ch/diesel/
There and There I read :
$(if, expr, dotrue [, dofalse])
and
$(IF,expr,dotrue,dofalse)
Then, I could solve :
Current Tab number (only if 8 or 9 caracters in the tab name, i.e. F-A3 (n) or F-A3 (nn) :
$(IF,$(=,$(strlen,$(getvar,ctab)),8),$(substr,$(getvar, ctab),7,1),$(substr,$(getvar, ctab),7,2))
Previous Tab number (current tab -1) :
$(-,1,$(IF,$(=,$(strlen,$(getvar,ctab)),8),$(substr,$(getvar, ctab),7,1),$(substr,$(getvar, ctab),7,2)))
Following Tab number (current tab +1) :
$(+,1,$(IF,$(=,$(strlen,$(getvar,ctab)),8),$(substr,$(getvar, ctab),7,1),$(substr,$(getvar, ctab),7,2)))
Thanks again,
Regards
and
Thanks again,
Regards
TomBeauford
TomBeauford
I've used Lee Mac's code for this in building my layout template blocks https://lee-mac.com/layoutfield.html
I added a function just for the sheet number to the code and autoload it with acaddoc.lsp.
  Layout Number
  Generates a field expression referencing the position of the layout in which the selected annotation object resides.
(defun c:lfnumber ( )
    (layoutfield
       '(lambda ( obj )
            (vla-put-textstring obj
                (strcat
;                    "Sheet "
                    "%<\\AcObjProp Object(%<\\_ObjId "
                    (LM:objectid (layoutfield:layout obj))
                    ">%).TabOrder>%"
  Total Sheets
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
  Layout Number
    (layoutfield
       '(lambda ( obj )
                (strcat
;                    "Sheet "
                    ">%).TabOrder>%"
  Total Sheets
2023
AutoCAD Inside the Factory
