Identify duplicate linework
kzD1219
Message 1 of 8
kzD1219
Is there a way to identify duplicate linework?  I need to know where the duplicate line work is?  I have very specific ways I need to draw the entities so there are going to be be some duplicate linework, but I want to check it before I delete it.
Replies (7)
Message 2 of 8
pendean
Community Legend
Community Legend
Like using OVERKILL command (usage explained in HELP)?
or something else, like homework assignment checking for copy/paste issues?
Message 3 of 8
cheryl.buck
Autodesk Support
Autodesk Support
Hi @kzD1219,
Good question. The most efficient way to remove duplicate geometry is with the OVERKILL command. You can make adjustments to the tolerances and specifics of what are removed, but there is not a way to examine it first.
You can also use the PROPERTIES palette to show the number of objects when you select a line or object with using a crossing selection box, before deleting the unwanted objects.
If a post answered your question or resolved the issue, please click the Accept Solution button.
Likes are always welcome.
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
Message 4 of 8
kzD1219
The only thing that makes me nervous about OVERKILL is it may delete a line that is actually supposed to be on top of another line.  The project we are dealing with asks for polylines and then closed lines wrapping around those polylines.
Ignore the arrows, but this is the kind of scenario we run into frequently.
Or say a closed line for a cabinet up again a wall and then a closed line for a countertop, and the lines against the wall are the same length, just different layers.  Would overkill delete one of those lines?  There are red lines underneath the cyan lines.
This is why I was wondering if there was any way to identify overlapping lines before deleting it.  I am ok with overkill deleting all those little 0 length lines that sometimes appear.
Message 5 of 8
pendean
Community Legend
Community Legend
There is nothing in between OVERKILL and you manually doing what you have done really, it becomes too custom a solution for a generic tool.
Why don't you test it and find out? SAVEAS to create a dummy test file to eave your original intact.
Message 6 of 8
rkmcswain
Perhaps. Does your AutoCAD license include the so called "toolsets"? If so, download and install AutoCAD Map, load your drawing, then run the command MAPCLEAN. When you get to the "Cleanup Actions" part, be sure to click on "Interactive mode".
R.K. McSwain     | CADpanacea | on twitter
Message 7 of 8
parkr4st
Duplicate lines would have exactly the same attributes?
Lines on different layers in the same space are not duplicates?  layers are attributes of the line?
Can you post an example?
Message 8 of 8
rkmcswain
IDK @parkr4st - you'll have to ask OP ( @kzD1219  )
