ICS File extension
ICS File extension
AllenJessup
Mentor Mentor
ICS File extension
AllenJessup
Sometimes when I attach a DEG file to an email in Novel Groupwise it will add an ICS file extension. That prevents the recipient from opening the file. I know it can be renamed. But sine most have Windows explorer set to hide known extensions they don't see the ICS.
The drawing gets saved as <filename>.dwg.ics.
I tried to get our IT Dept to diagnose the problem. But they're claiming the problem is that the ICS file extension isn't associated with AutoCAD and the user needs to make AutoCAD the default program for opening ICS file.
What I'm looking for is confirmation that AutoCAD doesn't create or open ICS files.
Allen
Civil 3D 2012 SP 3 / IDSP 2014
Dell Precision T3610, Xeon CPU 3.70 GHz
Win 7 Pro, 64-bit,32 GB RAM, Nvidia Quadro K4000
Samsung SSD 512GB, HGST (WD) 512GB drive
Allen Jessup
CAD Manager - Designer
Alfred.NESWADBA
I'm sure AutoCAD does not know ICS as file extension, and so it does not  open it (or handle such a file directly).
I have no idea why GroupWise does that. I'm not working with GroupWise, but adding an extension to files is not a good workflow generally.
Searching for "GroupWise" and "ICS" finds only calender-specific blogs/forums/threads/... (>>>Wiki about iCalender<<<).
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
AllenJessup
Hi Alfred,
That's pretty much what I find. I started an SR with Autodesk so that hopefully I will get official confirmation to pass on to our IT tech. There seems to be some misscomunication on this subject that I'll have to clear up before I can get any further. A big problem is that it seems to be intermittent and I haven't figured out what triggers it.
Thanks.
Allen
Allen Jessup
AllenJessup
Autodesk Support has confirmed that there are no ICS file created. It's a bug in our current email program. That's slated to be replaced in a couple of months. So we'll use a couple of workarounds until then.
Allen
Allen Jessup
tomasz_stachowiakTED52
Community Visitor
Community Visitor
AFAIK .ics file is/was created with IronCAD software. It's 3D file.
