ICON MENU
ICON MENU
newsgid
ICON MENU
newsgid
@Anonymous
Dear Sirs:
I am trying to build an image tile menu.  I've been at this quite a while and cannot seem to duplicate a previous success.  Maybe you can help.
Thanks.
I am running AutoCAD 2007 with Windows 7 on a Dell Dimension E520.
Recently, upon your suggestion, I reinstalled AutoCAD.  I got back my pull down menus and image tile menus.  Although they needed work, I felt I was making progress and had something I could work with, namely my .cui file.
I then proceded to go to TOOLS>OPTIONS>FILES and add my block and slide files under my standard support subdirectory.
I then get:
"error loading dialog control file"
"dialogs not available because dcl files not loaded."
My .cui file loads sucessfully but I suspect there is something about FILES support structure that I don't understand.
You have been very helpful in the past; I hope you can help.
Very truly yours,
Sheldon Goodman
cadffm
Hi
Please share a sample.
Sebastian
Moshe-A
@newsgid hi,
it looks like you have lisp files\commands 'who' uses dcl files. you need to add the dcl folder to support file search path  also.  generally, dcl files is reside on the same folder as the lisp files.
Moshe
newsgid
Sorry, can't share it...it's proprietary.
