- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Basically, we set up our file names with a _ at the end of the filename.
I want to create a field that only shows the content behind the _
for example -> ABC123ABC_0 / i would like it to show ABC123ABC
Remembering that our filenames have a standard number of characters. My codes are always going to change, the only thing that remains a standard is _ separating the content, so i can't use the solution performed, e.g. here -> can-you-make-a-field-to-show-only-part-of-the-filename or here -> parsing-filename-into-individual-fields
Appreciate any help
