Hi @HullDrafter
This happens when you are using the express tools (like BURST, ATTIN, ATTOUT, SUPERHATCH etc) and hit escape key(cancel) in between the command. It would be back to normal once you restart AutoCAD. if it doesn't then you need to reset AutoCAD to default. Here is how you can do that: How to reset AutoCAD to defaults 🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
