Autocad spacebar issue and hatch set origin issue
ctnasma92
ctnasma92
Currently I using Autocad 2020 and I facing two issue I never met before.
First at all, the space bar bug, every time I use shortcut command. spacebar create some problems to me.
example:  After I select object, I type M and the command direct go to Displacements but not specific base point. Sometimes it come back to normal.
Secondly, when I using Hatch function, right click menu set origin point doesn't accurate and run off. I only able to use the set origin button in the menu to get correct position.
ennujozlagam
have you try to install latest hotfixes/updates from autodesk and see if helps. thanks
ctnasma92
The hatch original solve but the  spacebar issue still exist.
now to avoid the issue i have to use Enter as the shortcut key. For me, this spacebar issue quite inconvenient.
cadffm
Solutions in the past for issues with this double-Space problem.
Install latest Acad update
Dock on your commandline (CTRL+9), docked commandline is over the full width.
Turn of selection cycling (CTRL+W)
And so on.
If nothing helps: Export your settings as backup,
Reset to default.
If this step is not enough, clean deinstall, clean install (means also to NOT import setting from prior version)
Sebastian
Kent1Cooper
@ctnasma92 wrote:
.... the space bar bug, every time I use shortcut command. spacebar create some problems to me.
Maybe your spacebar is faulty, and is sometimes registering twice when you press it.  If you use a different keyboard, does the same thing happen?
Kent Cooper, AIA
ctnasma92
I try almost all the solution.
After I reinstall the autocad and upgrade to 2021 and the problem solved.
ctnasma92
I haven't try this but after reinstall AutoCAD the problem solved.
