I have really hard time to find my drawings in model space
Message 1 of 8
I was trying to insert my drawings to layout and when I got back the drawings in model space disappeared I tried Zoom and ... but to mo avail is there any type of command to bring it back?
Replies (7)
Message 2 of 8
imadHabash
>> ....and when I got back the drawings in model space disappeared
disappeared where !!! i mean have you save your works ? what happened that make your drawing disappear , any doubts ? can you attache here your CAD drawing for testing ?
Imad Habash
Message 3 of 8
Patchy
Insert in paper space then you can't see in model space, that's how it works.
Message 4 of 8
Yes drawing is there as when I use SELECT ALL,the objects are selected I am
lost in the space maybe because too many zooms,
Message 5 of 8
ian.mag
Hey,
Probably they are zoomed out very far. Try zoom extents by double clicking your roller mouse or typing Z enter, then E for extents.
Message 6 of 8
pendean
Community Legend
Community Legend
Why are you inserting DWG files into layouts? Are your DWG files show content that is no bigger than a sheet of paper in size?
Or do you need help using both XREFs and LAYOUTS/Viewports in AutoCAD?
Let us know.
Message 7 of 8
GrantsPirate
Are you able to view the drawing in a viewport in a layout?
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Message 8 of 8
TerryDotson
Most likely you have some stray geometry, for example something at 0,0 while the bulk of your geometry is in the thousands, etc.  Try using zoom center and entering a known good coordinate, then zoom out slowly till you see the extents of what you expect.  Then carefully enter erase all, enter R for remove, then window the good parts.
