I find that the objects selected when zoomed out get unselected when I zoom in
when I select some specific set of objects and zoom in to put in the final point, I note that the objects previously selected get automatically unselected, which ends up being very irritating.
How can I ensure that whatever I have selected continues to be selected, whether I zoom in or not ?
-Harshal
imadHabash
Hi and Welcome to AutoDesk Forum,
>> when I select some specific set of objects and zoom in to put in the final point <<
usually and if you use mouse scroll to zoom in and out selected objects keeps selected till you finish your procedure.please till us how did you select objects and how did you zoom while selecting?
Just guessing ... check PICKFIRST to be set to 1 .
Command: PICKFIRST
Enter new value for PICKFIRST <1>:
Imad Habash
cadffm
The Objects should visible on Screen by accept last point.
Its normal.
Since 2017 Sp1 its Changeable by a new Sysvar.
http://help.autodesk.com/view/ACD/2018/ENU/?guid=GUID-2609B540-EF39-45B5-8682-FEC7F16B77DE
Sebastian
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
What version of AutoCAD are you using? AutoCAD 2017 & AutoCAD 2018 both support retaining off-screen selections. Prior versions do not.
John Vellek
