Copy Paste Viewport Properties
MikeKovacik4928
Advisor Advisor
Message 1 of 18
MikeKovacik4928
I only seem to have found this problem lately since I have been using AutoCAD 2018. Unless it is caused by something else?
When  I copy paste a viewport to another drawing, it seems to lose its "viewport freeze layer" properties. In other words,
the viewport In the drawing where I have copied it to, had everything visible, as opposed to the original drawing where I copied it
from, where there were some layers invisible inside the viewport, by virtue of themhaving been "viewport Frozen"
Anybody else encountered this, is there something special that has to be done to get these "viewport frozen" layers across?
I can't recall ever having this problem in AutoCAD 2017 & previous.
Michael Kovacik
AutoCAD 2d & 3d (29 yrs)& Inventor (7 yrs)
Manufacturing (30 yrs) Draughtsman
Autodesk Product Design Suite Ultimate 2018
Johannesburg, South Africa
Replies (17)
Message 2 of 18
chriscowgill7373
I just tested in 2017 and I'm seeing the same thing you are, when pasting the viewport into a new drawing, it looses the vpfreeze layers.
a way around it is to create a layerstate in the original drawing, and export it, then import it into the new drawing.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2024 on Windows 10
Message 3 of 18
AFAIK, it's always been that way.  I've never known it to be otherwise, just checked in 2015 and 2013.
Message 4 of 18
pendean
Community Legend
Community Legend
I can confirm AutoCAD 2017 and 2016 behave the same exact way as you see in AutoCAD2018.
Message 5 of 18
MikeKovacik4928
Thanks all
So you have never been able to do it in previous autocad's either.
I didn't realise
To answer someone else's suggestion
I am aware of using layer states in model space, and I do use them,
but they don't match up to my viewport Freeze layers which are usually
unique for each viewport.
I guess I will just have to refreeze the layers again in the viewport which has been copied
from one dwg to another.
Does anyone think this would be a useful thing to have?
I personally do, and would like to post it as an idea, however I won't do unless
others think it is useful too.
Michael Kovacik
Message 6 of 18
chriscowgill7373
I may have not been clear on my original post, when I was referring to double-click into the viewport and save the layerstate,  which then maintains viewport freeze property.
Message 7 of 18
john.vellek
HI Michael, Is copying an entire layout an option? You can do this with Design Center and If I remember correctly, the viewports that come over will retain their properties as well.
There are also a bunch of viewport related tools in the Autodesk App Store that might be worth investigating.
John Vellek
Message 8 of 18
MikeKovacik4928
Thanks Chris
I now understand perfectly.
That is exactly what I am after!
Amazing, how after 20 years, one continues learning new
things about AutoCAD!
That is the beauty of these international forums!
Mike
Message 9 of 18
MikeKovacik4928
John
This is definitely an option.
I can't figure how to do it though.
I open design centre, and right clicking on the layout gives me the copy option,
but going to the new drawing and trying to add this layout, I can't find any paste option.
I tried to drag it from on drawing to another, that didn't seem to work either.
Mike
Message 10 of 18
john.vellek
Hi @MikeKovacik4928,
To copy the layout, it has to have a unique name. If you can see the layout in DesignCenter, simply drag it onto your drawing file and it should show up.
And my memory of how the layers will come in is apparently wrong. Here is an article that indicates I must have been dreaming.  It indicates steps similar to those suggested by @chriscowgill7373.
I apologize for any confusion.
I did find this app in the Autodesk App Store that might do the trick for you.
John Vellek
Message 11 of 18
I tried to add it to the AUGI wishlist list several years ago to no avail, and there isn't an IDEAS page for plain AutoCAD.  You might be able to get it added to a vertical by using that verticals IDEA page.
Message 12 of 18
Another quick way to do what you are after, copy a viewport and retain its properties, is to first turn the viewport into a block. Then just copy/paste the block and explode it after inserting - All viewport properties, layers etc are retained.
Message 13 of 18
MikeKovacik4928
Carl
Thanks for your input.
Yes that works for a new layout on the same drawing, but doesn't work if
you are copying the blocked viewport onto a new drawing which has the same layers.
On the same drawing you could just create a copy of the  layout anyway and get the same effect,
without having to block the viewport.
You would still have to  click inside the viewport and save it as a layer state, as stated by Chris.
A pity Robert's wishlist idea was not incorporated into the software, but Chris's method
is a good workaround and doesn't take too long to do anyway
Mike
Message 14 of 18
cadffm
If you want the hole Layout, why not import the Layout? Thats the fine way
and for Standard Layouts (every time the same source file) you can use a one-click macro.
_layout Option template _t
_
For your Way you have only to copy your objects and after set, set the viewport properties (Layer overrides) new with command MATCHPROP (make sure you enabled the special viewport property in matchprop setting)
Sebastian
Message 15 of 18
MikeKovacik4928
Sebastian
Not too sure what you mean by importing the layout or how to do it
Copying my objects in model space to a new drawing.
Then copying the viewport in paper space to the new drawing
does not give the vpfreeze settings.
Using matchprop on the vp in the original drawing to the vp in the new drawing
does not bring across the vpfreeze settings. You have to redo the vpfreeze all over again.
So I am not too sure what you are talking about here either.
Can you give me a more detailed explanation please, or a screencapture
or a screencast.
Mike
Message 16 of 18
cadffm
Hmm, now i am not sure what i should answer.
"Copying my objects in model space to a new drawing."
Why? And do you copy ALL objects or only a part of Modelspace?
Why do you not saveas to another filename?
"Then copying the viewport in paper space to the new drawing"
Why?
And why only the Viewport?
Help me to understand.
I do not know why you are using these steps and why not other ways.
Note: I dont say that is wrong, only that this is unusual (for my workflow) and i for better help i need to understand why you do that.
"does not give the vpfreeze settings. Using matchprop on the vp in the original drawing to the vp in the new drawing does not bring across the vpfreeze settings. "
It should, if you set your matchprop setting for the special viewport properties, thats i wrote above too.
Start matchprop and choose an object, take your viewport gor example.
then go to the options, make sure VIEWPORTS is enabled.
Which program version are using?
"Not too sure what you mean by importing the layout or how to do it"
Thats the way if you want the whole Layout (TAB) incl. the Layout objects, not only a viewport.
Command Layout, option template.
Sebastian
Message 17 of 18
Thanks Chris,
I now have saved layer states for water, sewer, stormwater and pavement.
I copy viewports from one layout to the next so everything appears in the same location on each sheet.
loosing the frozen layers was very annoying!
Message 18 of 18
nnorBZEC3
Community Visitor
Community Visitor
Wow, really helps and it works..tq so much
