iHere i enclosed the drg file Autocad2018 format. I could not able to plot the drg. the error msg is coming. I opened the new file and copied the contentents. But same problem i am facing. Anyone advise me.
Solved by Alfred.NESWADBA. Go to Solution.
Which message do you get?
I can see 2 issues
But changing the plotter to e.g. "DWG to PDF.pc3" I can plot your drawing well (please find PDF attached).
- alfred -
I dont remember the error. The plot preview just pop up and coming back. You use any ctb file. I also did the same thing pdf. But I want know the reason
Then please repeat the same procedure to get the error presented ... or does it not happen any more?
So you got a correct PDF?
For now I don't even know what exactly happened on your system, which error and which result you have got.
For me that makes it impossible to give a description of a reason about an error we don't see (and don't know).
- alfred -
the message states "no matching media", you should select a different paper format (could be the same size, but a different name) or you create a new PC3-file for this output device (using command _PLOTTERMANAGER and then the "add-a-plotter-wizard"). Then use this new PC3 file and the paper format presented for that device.
- alfred -
