I cant type distance of lines, ...
Hi, i am student and I have to work on some school projects but i cant cause it doesnt let me type numbers when i am drawing. For example i want to make a line that is long 1000. Under normal conditions i would click where i want to have a start of the line, choose direction of it and then type the number 1000. But i cant, it doesnt let me. Pls help, i dont have much time.
Kent1Cooper
What does "it won't let me" mean?  What do you see when you type?  Are you using the number keypad typically at the right end of a keyboard, but without NumLock on?  Does it work if you use the number keys across the top instead?
Kent Cooper, AIA
pendean
Community Legend
Community Legend
Ask your teacher for guidance, here is how it is done if you want to read before you talk to him/her about it https://itstillworks.com/draw-line-give-length-autocad-8476804.html
or if you prefer a video https://www.youtube.com/watch?v=z56HBi2nMeU
HTH
I just cant type anything. I tried to use both of the numpads (with numlock on) and nothing happened. I tried to reinstall and update the program but nothing changed. But thanks. 😞
I will have to ask, non of the links help. But thanks.
pendean
Community Legend
Community Legend
Are you on a laptop?
Most have a special button you need to press in order to press the correct keys/functions.
Otherwise you need I.T./tech support, doesn't sound like an AutoCAD problem.
