I can't fillet. Shows failure while filleting
Please can anyone assist me in getting the attached file filleted? I'm trying to design a logo for a watch store called watchmen. I can't seem to get it correctly. Any help would be greatly appreciated. And also any suggestions on the material I should apply.
parkr4st
radius?  .5 doesn't work, .25 or .34  or.4 or .45 does work   .495 doesn't
I've tried it too, it just doesn't work, some edges can be filleted, while others can't. And I don't know why. Can you try it if you can come up with something?
Alfred.NESWADBA
I would not use SPLINES for the contour of this logo, recreate the contour with polylines and all will work better.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
S.Faris
Please highlight the edges that can't be filleted so that it will be easy for us to understand what the issue might be . That will help us save a lot of time
SALMANUL FARIS
imadHabash
it seems fine with me ... try FILLETEDGE command ( change radius option value ) . make your model orientation as shown below then active FILLETEDGE command and select edge corners then double enter .
Imad Habash
