Hi
It's not a bug in 2025, it's a problem on your side.
AutoCAD for MAC don't have this problem, because MAC don't have Ribbons 😉
Sebastian
The ribbon for the Mac version is on the left side of the screen, isn't it?
I can use the “ribbon” and “ribbonclose” commands in AutoCAD for mac just fine.
Try downloading and installing AutoCAD 2024 for Windows to see if you encounter the same problem on your system
For reference:
@phusipaphawong_t wrote:
- After installing the program AutoCAD 2025 for window 64bit. ... I tried using the “ribbon” command, it says “unknown command ribbon”. ...
Apply the suggestion from this link:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
You may want to clarify how you are running AutoCAD for Windows on your Mac like using Parallels?
- After installing the program AutoCAD 2025 for window 64bit. When I open the program There is no ribbon on the screen. ...
Since all of us running Windows10 and Windows11 with AutoCAD 2025 can do this, what is unique about your setup that is likely not being replicated by anyone in this WindowsUsers-exclusive forum?
And did you perform a full AutoCAD2025-for-Windows reset yet? Here is how
I don’t use parallels on mac. I have AutoCAD 2025 on pc window and on mac.
Ok so your AutoCAD 2025 on your pc is not working properly. If you’re on subscription try downloading 2024 and install that version to see if that solves your problem
