AutoCAD Forum
I can not editing a block with BEDIT
2 REPLIES 2
carlos.a.duranCEUNR
826 Views, 2 Replies
Hi guys. I am working with a block  I can edit the atributes, etc, but I can not use the editor block, so when I write the command BEDIT in the list I can not see the original block.
In the properties, this block is called with the next symbol *
I need help.
Thanks a lot
2 REPLIES 2
That is an "anonymous" block, and you are correct, they will not be available for editing in BEDIT.
See here for more info
R.K. McSwain     | CADpanacea | on twitter
Ok thanks a lot. You are a genius.
Bless
AutoCAD Inside the Factory
