I am not able to see create view tab in layout menu
Message 1 of 9
When I select layout, I go to layout tab and there I see only two tabs layout and layout viewport , create view tab and other in not available it has just disappeared, I tried reinstalling still nothing
Replies (8)
Message 2 of 9
j.palmeL29YX
Try to "Reset Settings to Default" (in Window Start Menu->All Programs->Autodesk->AutoCAD).
cadder
Jürgen Palme
Message 3 of 9
Did resetting from the menu bar of the window ,still the layout tools in layout tab are missing, can you please tell me what to do
Message 4 of 9
j.palmeL29YX
Did you read this thread:
https://forums.autodesk.com/t5/autocad-architecture-forum/create-view-panel-missing-from-layout-ribb... ?
cadder
Jürgen Palme
Message 5 of 9
imadHabash
as seen from below image ... please try to right click on Layout tab >> Show Panels then tick other tab options to dispaly .
Imad Habash
Message 6 of 9
In show panels I am able to see only layout and layout viewport option.
Message 7 of 9
But I am not using Auto CAD architecture version I am using AutoCAD 2018 32 bit version.... Please tell me what to do....
Message 8 of 9
j.palmeL29YX
The next I would try is a repair installation.
If this also doesn't help a new installation of the product can be necessary.  A clean uninstallation is recommended beforehand (see https://knowledge.autodesk.com/customer-service/download-install/remove-products/clean-uninstall and https://knowledge.autodesk.com/customer-service/download-install/remove-products/remove-windows-prod...).
cadder
Jürgen Palme
Message 9 of 9
imadHabash
i suggest to read some solutions here in this AKN article that may fix your issue . >> Click <<
Imad Habash
