We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
HVAC Design Layer Color Code
Dear Sir
I have a query regarding hvac  system  drawing.
which color code i choose in supply air duct & return air and other many other equipment related to hvac .
i dont know what is the standard color code for hvac design so please tell me where i get download for
imadHabash
HI,
>> i dont know what is the standard color code for hvac design so please tell me where i get download for <<
color code is following to your firm CAD standard !! ask your CAD manager or the technical man and follow the instruction .
Imad Habash
Dear Sir I Wan As Per Indian Standard.
imadHabash
>> Dear Sir I Wan As Per Indian Standard. <<
The best way is to ask around you and from the specialist people !! try to contact them and take the right answer.
all the best,
Imad Habash
3wood
The most important thing is put your HAVC stuffs in separate layers and set your objects to ByLayer color. You can then change the layer color to whatever later on.
timothy_crouse
Here is what I use
I insert the file into my XRef along with the basic layer standard.
Setup my xref
Then remove layer blocks and purge the drawing.
By having all my layers in the block they will not be purged if they are not currently used in the design.
NOTE - I use STB plot files,  if you use CTB)s) acad will do its best to line up the colors  >>  you will need to tweek colors to a color dialog
number value when using CTBs if it does not transfer properly  >> otherwise you will not get the color or gray scale you were expecting.
Hope this helps
