Huge File Size Increase When Inserting JPEGS
mgorecki
mgorecki
Just curious as to why the AutoCAD file size gets so big.
I have an AutoCAD drawing that has 8 layouts; the last two are blank waiting for 2 jpeg images.
The dwg = 425 kb
jpeg1 = 277 kb
jpeg2 = 194 kb
Once I insert both jpeg files using the Edit > Paste Special method (selecting metafile)
The dwg = 2527 kb
I used jpeg as they were the smallest file size option.
Is there a reason for the huge file size increase?
Mark
pendean
Community Legend
Community Legend
That is how the program works: it removes all compression from inserted raster files. That is why the ability to reference images instead keeps DWG files sizes in check.
scot-65
Have you tried placing image in the clipboard and accepting
the default actions inside the Past Special dialog?
To place image into clipboard:
Open image FROM your favorite file manager TO your favorite web browser.
Right-click on image and select "Copy".
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
mgorecki
Hi Scot,
I'm not sure I understand what you're describing.  In Windows Explorer, I selected the jpeg and right picked "Copy".
In the drawing, I did the "Paste Special" and put it in, but it was just like an icon of the image and not the image.
Best regards,
Mark
mgorecki
I even picked the jpeg in the Windows Explorer and right picked Open With Internet Explorer.  I picked Edit > Select All, then Edit > Copy.
I went to the AutoCad drawing, but Paste Special was not an option, it was grayed out.
