your screenshot shows its installed
what are you trying to do?
if your trying to reinstall try using this tool from microsoft: https://knowledge.autodesk.com/customer-service/download-install/remove-products/using-microsoft-fix...
FYI
how to take screenshots: https://www.howtogeek.com/226280/how-to-take-screenshots-in-windows-10/
the screenshots come in clearer than using a camera
DarrenP
I loaded it but can't press install. I do not understand why.
Because these 3 applications are already installed.
You can't install something that is already on your system.
- alfred -
Very strange because I deleted and reload. But the program is already installed and cannot be found.😭
>> because I deleted
Well, I hope you have not deleted the folder, because that is not the same as uninstalling ... even worse, it's killing the internal structure of registry, user settings, shared files.
So the need you have now is to first try to cleanup this defects, follow this advice's for clean uninstall >>>click<<< (you might need MS-Fixit too >>>click<<<)
- alfred -
thx u very much.
@Anonymous - you might want to do a complete wipe of all Autodesk products and start over. Hope you have few hours to kill. Good luck.
