How to wipeout SPLine or arc ?
theethawach_lekphat
theethawach_lekphat
Community Visitor
Community Visitor
Draft equipment,
I want wipeout boundary of equipment (Have Arc + Line + Polyline + Circle).
Normally wipeout used with Polyline or Polygon. But equipment drawing have Arc + Line
Wheelie22
And because it is not a polyline, do it right the first time, you can not add or remove a point afterwards... 🤔
Snap on a small number so you can select a few points on the arc and the Object snap mode with Nearest on.
And Goooo...
j.palmeL29YX
@theethawach_lekphat wrote:
... have Arc + Line
A wipeout allows only straight lines as a boundary. That is, you must replace the arc(s) with a series of line segments (and, of course, join all segments into a polyline).
You can do that either manually or use one of the LISPs which you can find around. (one example attached).
Jürgen Palme
Kent1Cooper
See the PLALS command defined in PolylineArcsToLineSegments.lsp, >here<, and that topic generally.
Any Wipeout-basis Polyline will need to be closed, so an Arc by itself won't do -- you would need to join Arcs/Lines into closed Polylines first.
If you have a closed Spline, you can just use SPLINEDIT's Polyline option, which will result in a Polyline of only line segments, which you can make into a Wipeout.
Kent Cooper, AIA
