How to use this type coordinate system to solve this question in AutoCAD?
Xiao16
Xiao16
Patchy
Nobody on earth can help you if you don't attach your .dwg
Kent1Cooper
You can use a BOUNDARY or BPOLY command to make a Polyline with the shape of the common area, and then see its area in Properties.
Kent Cooper, AIA
spear_kevin_pe
Surveyors units is an angle setting in the UNITS dialog. Then, enter the bearings and distances as noted. Shaan Hurley writes the AutoCAD blog and detailed this concept there - Drawing with Surveyors Units in AutoCAD (Between the Lines) (blogs.com)
Kevin
Kevin Spear, PE
chadwickt
In addition to drawing a boundary like Kent suggested, you could also hatch the common area, and find the area of the hatch in the Properties palette.
