How to use the downloaded local help
Karol-Or
Karol-Or
Autocad 2013 SP 2
Every time the laptop awakes from sleep the online help is off and i have to start searching again. i want to remain where i left off and continue using help, that's why i installed the local version of help but no use, i can't use it. Acad still uses the online help, while i want, entirely, to use the downloaded local help.
I uninstalled it long ago but want to try again
john.vellek
HI @Karol-Or,
The oldest version that I have is AutoCAD 2014. The process should be similar.
Once you have downloaded the Offline Help, go into Options>System tab and uncheck the Access online content when available.
John Vellek
john.vellek
Hello @Karol-Or,
I am checking back to see if my post helped you with your problem or if you need additional assistance or information. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if my post solves your issue or answers your question.
John Vellek
