How to use SUMIF formula in Autocad Table
Boopathy_Karthikeyan
Message 1 of 8
How to use the SUMIF formula in Autocad in without any Purchase application.
Generally we have sum, Average, Count etc., But i need to use the SUMIF to for special purpose.
I here attached the Table with formula.
Thank in advance.
Best regards...
Boopathy K
Best Regards..
Boopathy K
Replies (7)
Message 2 of 8
leothebuilder
Tables in Autocad are unlike Excel and are limited to formulas you are able to use.
Message 3 of 8
pendean
Community Legend
Community Legend
SUMIF is not supported in an AutoCAD table.
Data Link your Excel spreadsheet with SUMIF to your DWG file instead.
Message 4 of 8
thanks for your reply.
I don't want to use the datalink that why i am trying this method, Why Because this table Column can be increase or reduce i dont want to open excel every time to update the drawing, also i have almost 50 to 60 autocad files for every file i cant maintaining the separate excel sheet for all the drawings its not possible.
Best Regards..
Boopathy K
Message 5 of 8
pendean
Community Legend
Community Legend
What you want has no bearing here sadly: it's your only free choice to date within the TABLE features.
I'm not seeing an alternate using another custom FIELD option so far, maybe someone else has.
Message 6 of 8
I thought there may be will be some solution, If not i will follow my old producer.
Here actually i need to calculate the every Feed and Rapid individually, 5 or 10 rows we can but there are more the 25 so i try to reduce my time by using this formula.
But i like to thank you people, for your immediate support.
May be Auto Desk can take care of these type of functions in advance version.
Best Regards..
Boopathy K
Message 7 of 8
john.vellek
Hi @Boopathy_Karthikeyan,
I found this utility in the Autodesk App Store. It appears to give more formula capabilities than are built-in.  I hope this helps.
John Vellek
Message 8 of 8
I aware of this Add-on application,
This i need to purchase, actually i don't know my organization will do this! any way may be this will useful for some other!
Thanks John...!
Best Regards..
Boopathy K
