How to update source tool palette location?
Message 1 of 8
Already tried the "tool palettes file locations" in options. Doesn't works.
Updating path of every block will take too much time
Replies (7)
Message 2 of 8
cadffm
It works.
This has nothing to do with "tool palettes file locations"
If you need to update the pathes to your block library dwgs,
edit your palette content files with an TEXT EDITOR.
Copy the block source dwg files to the new folder,
navigate into your toolpalette path, palettes folder, use find&replace in your TextEditor
to edit the pathes into your *.ATC files.
Sebastian
Message 3 of 8
All the blocks are in one file. The file has been moved to another folder. Where is the “tool palette path”? it is in each block’s property
Message 4 of 8
cadffm
Where is ???
This is the main folder (if only one path is set there),
inside this folder (use windows explorer to navigate to the folder)
you should find a folder PALETTES, there are you palettes (*.atc) files.
If you have just few palettes and all of the items are insertion tools for blocks from this dwg,
you can also use CTRL+A inside your palette in ACAD, rightclick, properties... edit the path.
Sebastian
Message 5 of 8
[cid:image001.png@01D66F1A.A370F490]
I have updated the location here in options to the palette folder where the .atc file is.
It doesn’t works
To change the path in property is to open one by one of the blockes in the palette
Message 6 of 8
cadffm
Had you tried to attach something? You have to come in to the forum, then you can attach a file to your post.
WHY? Nobody said this and it is wrong.
Please set it back to the folder as before (to the folder where the folder "Palettes" is inside)
Make sure in this folder the file "AcTpCatalog.atc" is still present.
If there is another "AcTpCatalog.atc" file now in your ...\<this is your destination folder in options>\Palettes\H E R E,
then remove this file (and delete the file after all works again as expected)
No, you can select multiple block insertion tools in one step, or if all tools in one palette refers to this dwg
you can also use CTRL+A inside your palette, then right click, properties... edit the path.
Slow down, it isn't magic, take time to read and test, and make a backup of your files first.
If you fixed your option toolpalette path again, then open the right *.atc file with EDITOR (TextEditor)
and try to FIND&REPLACE
Sebastian
Message 7 of 8
HALLLELUYAAAA
ctrl+A in each palette , updating the path works ! ! !
THANK YOU !!! 🤗
Message 8 of 8
tjiran
Community Visitor
Community Visitor
THIS SAVED ME THANKS SO MUCH FOR TAKING THE TIME TO POST.
APPRECAITE IT.
