How to update annotative multileader contents without affecting positions in other viewports?
nw.yan
nw.yan
Hello everyone!
I am facing a problem with annotative multileader.
Every time I update the contents of annotative multileader text, the positions of that multileader
in other viewports are moved to current position. May I know how to prevent it?
I attached the screenshots here. Currently I am using Auto Cad 2021.
Yan
imadHabash
can we have a CAD dwg sample please ?
Imad Habash
nw.yan
Thanks for reply and I attached here the sample files.
Yan
imadHabash
Thanks for your CAD dwg file . when i open your files :
  • Why you're using Multileader object since you don't have use the leader itself [ you just used the text ] ?
  • There is Nothing weird in your drawing and all texts are stable in their places !!! try to make numbers as seen below to know what is happenings .
Imad Habash
nw.yan
Hi ,
Thanks for reply.
So sorry that I could not explained clearly in words.
Please look into attached video.
I understand that I can use Multiline text instead and there is no issue like this but I have certain reason to stick to Multileader as text if I know how to solve this position matter.
Appreciate your help.
Yan
imadHabash
Ahhh ... Now it's clear !! 🙂
Click on below image to see that this happen because of another annotation scale called SSO1 which have another position than 1/250 . So just change your VP annotation scale to 1/250 and every thing will be fine .
Imad Habash
nw.yan
Hi ,
Thank you so much for your time and afford to help,
but it did not solve the problem I am facing.
Multileaders are fine and stay its positions until the contents are being edited as I showed in video.
And I need to use the different annotative scale for respective viewports (such as SS01 for layout SS01).
Anyway I will use multiline text instead as you suggested in earlier post.
Thanks a lot.
