How to ungroup or separate a group of 3d solids (block reference)
Message 1 of 12
I grouped several 3d solids seleciong them and then right click- group- group.
I did that not to loose them when modelling.-- but maybe it was a stupid option...
Now I am unable to ungroup them. They are no longer 3d solids, they are now a block reference.
I need to "ungroup" or separate them, but not explode them (becuase I need to put materials and I don't want to brek them).
If I apply a materail to the block reference it changes all the solids on it, and I need diferente materials.
Normally I find all the topics I need, but this time I can't find it. I tried to copy and paste to another drawing, change layer, restarting etc.. HelP!
I am working with Autocad 2012.
Replies (11)
Message 2 of 12
I forgot to say I grouped the 3d solids and then they "became" e block reference instead of a 3d solid group.
What can I do to separate the solids of a block reference ?
Message 3 of 12
Patchy
How about UNDO?
Group works fine for 3d.
Let's see your 3d Drawing.
Message 4 of 12
I attached the dwg.
Thank you in advance!
Message 5 of 12
I attached the dwg.
Message 6 of 12
Patchy
Oops, if the file is too large, you need to ZIP it.
Message 7 of 12
zip
Message 8 of 12
Thank you.
Undo won't help beccause I did a lot of 3d solids after... and saved it ..
Message 9 of 12
Patchy
http://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/AutoCA...
Does this work? (Separate 3d) my autocad is an older one, I can't do it.
How about Slice it and get it back?
Message 10 of 12
Yes, Slice and then union solved some 3ds, but not all ( the ones with
curved parts i can't separate...)
Maybe there isn't a solution.. Maybe I shouldn't have clicked "group
solids".
Can you advise me what should i do instead of grouping several solids??
I don't want to loose sólids when i am modelling, that's why i grouped
them...
Message 11 of 12
Patchy
3 are different.
Group, union and ungroup.
I don't know how did you use group and the model unioned together, the model should go back to 2 different shapes after command ungroup.
Message 12 of 12
I see that you separated with Solid Editing -> Separate
and it worked in some objects!! THANK YOU!
It didn't work in all the solids- maybe because they were "intersecting solids", but it is better now.
I could't separate all the objects, like you did- some are stiil together- when i separate autocad says " the selected solid does not have multiple lumps. Enter a body editing option".
Meanwhile, I figured how to convert a "blockreference" into "3dsolid"- I tried exploding and worked.
