AutoCAD Forum
How to turn a 2-D image into a 3-D image
6 REPLIES 6
679 Views, 6 Replies
I am trying to make a 3-D model from a 2-D sketch I made.  I have only worked in 2-D so I'm not sure on how to do that. I have a sketch of heart with two names on the inside. I want to make the heart solid while leaving the inside of the letters open so you can see through the letters.  Attached is the sketch I made. Any advice is appreciated.
Thank you.
6 REPLIES 6
Patchy
You can use command PRESSPULL and pick between the letters and the heart.
or use EXTRUDE command,  after that use SUBTRACT command.
in reply to: Patchy
I tried that but all I was able to do was raise the letters.  I couldn't raise the heart or make them solid.
Patchy
Because the heart shape isn't slosed (joined together)
You can use command REGION, select the heart, then extrude all entities in 1 shot.
JDMather
Did you use Presspull (not Extrude)?
Steve_Bessette
Here is a short video that will show you how to make 3D Text.  You can then use this text to subtract from the other 3D objects.
http://screencast.com/t/qdNZaR0aVsAf
Steve Bessette
Support Specialist
Product Support
Autodesk, Inc.
Patchy
in reply to: Steve_Bessette
AutoCAD Inside the Factory
