How to snap perpendiclar to previous segment while drawing a line/pline segment and still in the command
KDAddison
KDAddison
When drawing a line in an arbitrary direction how do you get ACAD to snap perpendicular to the previously drawn segment while still in the line drawing command?  For example: LINE command -> click and draw in any direction -> click to add vertix -> now I want to draw the next segment perpendicular to the previously drawn segment, while still in the line drawing command.  I know there's a way to do this as I've had it happen unintentionally a thousand times, but now whatever unknown combination of snap settings and modes that made this happen is not selected and I need it back.  I've flailed around with snapping & tracking settings plenty to no avail.  What's the combination of settings and actions that enables this behavior?
paullimapa
Use Polar Tracking method.
At command prompt enter the following:
Options
Then select tab: Drafting
Under section Auto Track Settings: Check Display polar tracking vector and Display Auto Track tooltip
Next enter the following command:
Dsettings
Then select tab: Polar Tracking
Check Polar Tracking On (F10)
Under Increment Angle Settings select 90
Under Polar Angle measurement select Relative to last segment
Now you should be able to draw the next line segment perpendicular to the first by using Polar Tracking
Paul Li
IT Specialist
@The Office
KDAddison
Thank you I finally got it to work now!  The Relative To Last Segment option was the one I was missing.
paullimapa
you're welcome...cheers!!!
Paul Li
IT Specialist
@The Office
