AutoCAD Forum
How to set the text style
21 REPLIES 21
Message 1 of 22
4456 Views, 21 Replies
      When I open a cad file from friends my AutoCAD does not shows the exact text style as he set in his office or home.
It opens the normal font as attached image.
secondly, it does not has match properly.
Kindly help me in this regard.
21 REPLIES 21
Message 2 of 22
Kent1Cooper
Find out from them what font  is assigned to the Style of those Text objects.  You probably don't have the right font, and AutoCAD is substituting something like ROMANS or SIMPLEX.  Are there any messages about fonts when you open the drawing?
Kent Cooper, AIA
Message 3 of 22
rkmcswain
Right after you open this drawing, press F2 to open the text window.
Scroll up until you see something like this:
Substituting [simplex.shx] for [romans.shx].
Substituting [simplex.shx] for [A-EDED1.shx].
Substituting [simplex.shx] for [NARROW6.SHX].
In the example above, I have three fonts missing.
You can also go into the STYLE command, and browse each text style. When you find one with a substituted font, it will have a yellow shield by the font name, like this:
Find out what fonts are missing, and ask your friend for them (observe any copyrights). If they are .SHX fonts, they simply need to reside in a path, that is in the support file search path. If they are TTF, then they need to be installed in Windows.
R.K. McSwain     | CADpanacea | on twitter
Tags (3)
Message 4 of 22
in reply to: rkmcswain
Dear,
When I apply F2 then see the attached image result.
and when applying style command the attached dialogue box is open in which no yellow sign appears.
Message 5 of 22
in reply to: Kent1Cooper
No message appears when I open the drawing.
Message 6 of 22
rkmcswain
(A) You have to scroll up to the TOP of the F2 text window. Do this right after opening the drawing.
(B)That only shows one text style. Have you checked all 9 of them?
(C)Another possibility. You and your friend both have the same font (by name), but the contents of the font on each PC are different.
Message 7 of 22
A= I scrolled up the top of the F2 window but shows that who I sent you.
b= Yes check all the 9
c= by double-clicking on the text it will change the text style
But how I can change the text style of the all the file.
Message 8 of 22
pendean
Did they send you the font file along with the dwg file? Go ask them for it.
If you are not sure what to ask them for, post your DWG file here for someone else to point the font names out for you.
Message 9 of 22
rkmcswain
No, this is not the top of the text window.
The top of the text window will look something like this: (The first line will say "Opening an AutoCAD XXXX format file")
Put your cursor in the text window and scroll up. In a floating command line (such as yours), the scrollbar does not appear unless your cursor is hovering over it.
Message 10 of 22
Here is the top window
Kindly find the attached file.
Message 11 of 22
Here is the .dwg file.
Kindly suggest me the method by which I can change the all the text style of the file.
Message 12 of 22
Vinayv4v
When you open the drawing do you see the Missing SHX File dialog box ?
Enter command FONTALT  and enter <ARIAL>.
Save and reopen the drawing. Any changes ?
Cheers,
Vinay Vijayakumaran
Message 13 of 22
BeKirra
As I see the text style with room name is "standard" on your drawing and also they are MText.
Your "standard" text style uses "Arial.ttf" font but the text content uses "Baskerville Old Face.ttf" font. This can be seen on Properties dialog.
It looks likely you don't have the font.
Ask your friend for it.
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
Message 14 of 22
Alfred.NESWADBA
can you please upload the drawing so we can take a look into it.
Besides of that ... you are opening a file that is coming in a file-format from the last century. I would not be surprised if there are some items like fonts not looking identical.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
Message 15 of 22
in reply to: Alfred.NESWADBA
Here is the attached file.
Message 16 of 22
in reply to: Vinayv4v
Not any windows appears regarding .shx missing.
But after apply FONTALT command and enter the new value of ARIAL. all the text of the file has been changed to ARIAL font style.
Message 17 of 22
But the contents are same as before (fbaskervile old face)
Well
FONT ALT
what this command works.
Message 18 of 22
Alfred.NESWADBA
Same on my side, on my system not any SHX is missing, also the dialog of command _STYLES does not show any font missing
To be honest, that sounds like you have true-type font(s) copied instead of installed ... and Arial is the one that was installed and so recognized.
Can you please show a screenshot where we can see how the text looks like when you don't use FONTALT set to Arial?
- alfred -
Alfred NESWADBA
Message 19 of 22
Vinayv4v
Now does all the fonts in the below two drawings showing the same result as this.
Cheers,
Vinay Vijayakumaran
Message 20 of 22
BeKirra
Well
FONT ALT
Fontalt is not a command. It is a system variable.
There is nothing to do with "fontalt" in your case.
Type MTEDIT then select your text. You now should be able to see the font shown in the text editor is "Baskerville Old Face".
Change it to "Arial" you will be fine.
HTH
X² + Y² = C²
AutoCAD Inside the Factory
