How to set the "Border Offset Factor" value in Autocad using Autocad commands or Autocad Object Model?
edushka228
Message 1 of 20
edushka228
The task is to set the "Border offset factor" value for the active document in Autocad using Autocad commands or Autocad Object Model
Replies (19)
Message 2 of 20
imadHabash
The background in Mtexts or Multileaders with Mtext the Border Offset factor is equal to 1.5 by default.
  • You can select all of your Mtexts then press Ctrl+1 .. from Properties Palette  select Background mask set the Border Offset factor and the color as needed.
  • OR you can edit your registry file ( regedit.exe ) from your Windows OS . But you have to be careful when you do this to avoid any harm to your program.
Imad Habash
Message 3 of 20
edushka228
i need to change the default value using Autocad commands. Is there a command that allows me to do this? If not, how exactly to edit the registry?
Message 4 of 20
imadHabash
You cannot change it from AutoCAD commands!!
Open the Windows Run dialog box by pressing the Windows + R keys .
Imad Habash
Message 5 of 20
edushka228
I know how to open the registry. I don't understand how to find what I need in the registry.
Message 6 of 20
pendean
Community Legend
Community Legend
Message 7 of 20
edushka228
There is no TextMask_BackgroundScale parameter in the registry, but there are these ones. Which of them should be changed? I need to enter the value 1.1, instead of 1.5, which is set by default
Message 8 of 20
TomBeauford
I've looked be never found that windows registry key so let us know if you found it.
Many of them aren't saved or aren't saved where you'd expect.
I use Layer States extensively that only include layers they're designed to modify so to prevent the rest of the layers from being turned off I added this to my acaddoc.lsp to prevent it as the value isn't saved.
(vl-registry-write (strcat "HKEY_CURRENT_USER\\" (vlax-product-key) "\\Profiles\\" (getvar "cprofile") "\\Dialogs\\AcLayerApps:LayerStatesManager") "LayerNotFound" "0")
; Layer States Manager - Do not turn off layers not found in layer state
You're probably better off with one of those lisp routines, both of them work great!
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
Message 9 of 20
edushka228
I used the BGTOOGLE lisp you posted. It does not change the border offset factor.
Message 10 of 20
cadffm
If there isn't, it wasn't used before (or you are at the wrong registry path),
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\Rnn.n\ACAD-nnnn:nnn\MTEXT\
Sebastian
Message 11 of 20
edushka228
Message 12 of 20
cadffm
This is how it looks after install and you never used MTextbackground (in your CIVIL3D 2024).
Did you used MText-background in your Civil3D 2024?
If so, you have a problem: It looks like you (the program) don't have write access to this part of the registry
and that means - you have a lot trouble (not just the Mtext border scale).
Please test this:
Restart Civil3D 2024, create a MText and set background with a border scale of 3
Check the registry keys again, press [F5] for refresh regedit.
Still AutoStack the only item in this path?
Sebastian
Message 13 of 20
edushka228
I don't have civil 3d, I work in autocad...
Message 14 of 20
cadffm
But your screenshot showing a path for AutoCAD Civil3D 2024, not for AutoCAD 2024.
(so, Civil3D IS OR WAS installed on this PC)
This is AutoCAD 2024:
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R24.3\ACAD-7101:4nn
Sebastian
Message 15 of 20
cadffm
What's up?
If you don't have this folder:  C:\Program Files\Autodesk\AutoCAD 2021\C3D\   , you don't need to try this:
[Win]+[R]
open: "C:\Program Files\Autodesk\AutoCAD 2024\acad.exe" /ld "C:\Program Files\Autodesk\AutoCAD 2024\AecBase.dbx"  /product "C3D" /language "en-US"
[OK]
..to run Civil3D2024
Do you have this folder?
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R24.3\ACAD-7101:......................
Sebastian
Message 16 of 20
wispoxy
The answer is you cannot, it's not an option, it's hard coded with no public varible.
Message 17 of 20
wispoxy
It doesn't even work using the Action Macro Recorder.
Message 18 of 20
pendean
Community Legend
Community Legend
Message 19 of 20
TomBeauford
BGtoggle toggles the background On/Off of selected TEXT & MTEXT and sets 'Border Offset Factor' to 1.15, the background color to drawing background color and trims excess width.
Latest version attached.
You can set the 'Border Offset Factor' in the MTEXT dialog box or in the Properties Palette.
2023
Message 20 of 20
pendean
Community Legend
Community Legend
