Announcements
Suddenly many of the Blocks I have created are ever so slightly rotated.
kbriscoeV365Z
kbriscoeV365Z
I have installed autocad on a new computer. I'm using the same files where i store all the Blocks I have created. However now when i use the Tool Palette to put a block into a brand new DWG, or just copy the Block from the source drawing, and paste it, it will be very slightly rotated. I have no idea why this started happening.  The source Blocks are located in several source DWG files, so its not like one drawing got rotated. its all of them.
any suggestions?
pendean
Community Legend
Community Legend
Is this a problem in ALL files? Or just this one?
Is you SNAPANG system variable set to 0.000, or something else? You can look it up in the program's HELP if you want to learn more.
Are both your UCS and PLAN commands set to WORLD?
Would it help if you have no running osnaps at all?
