How to set Dimensions to Annotative using C#.NET
jlobo2
Message 1 of 10
jlobo2
We have a template setup with a "_STANDARD" dimension that is Annotative.
When we plot through the C# code below, we access the dimension, and set that.
The properties are being set, except for the Annotation. Can you please suggest what am I missing?CodeCodeResultResult
Replies (9)
Message 2 of 10
qnologi
Was this intended for the .NET Forum?
https://forums.autodesk.com/t5/net/bd-p/152
qnologi
Message 3 of 10
jlobo2
Message 4 of 10
Alexander.Rivilis
Try this sample code:
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
[assembly: CommandClass(typeof(DimChangeAnno.MyCommands))]
namespace DimChangeAnno
  public class MyCommands
    [CommandMethod("ChgDimAnno")]
    public void ChgDimAnnoHandler()
      Document doc = Application.DocumentManager.MdiActiveDocument;
      if (doc == null) return;
      Editor ed = doc.Editor;
      PromptEntityOptions prOpt = new PromptEntityOptions("\nSelect Dimension: ");
      prOpt.SetRejectMessage("\nIt is not Dimension!");
      prOpt.AddAllowedClass(typeof(Dimension), false);
      PromptEntityResult prRes = ed.GetEntity(prOpt);
      if (prRes.Status == PromptStatus.OK)
        using (Transaction tr = doc.TransactionManager.StartTransaction())
          Dimension dim = tr.GetObject(prRes.ObjectId, OpenMode.ForWrite) as Dimension;
          switch(dim.Annotative)
            case AnnotativeStates.False:
              dim.Annotative = AnnotativeStates.True;
              ed.WriteMessage($"\nAnnotativeStates.False -> {dim.Annotative}");
              break;
            case AnnotativeStates.True:
              dim.Annotative = AnnotativeStates.False;
              ed.WriteMessage($"\nAnnotativeStates.True -> {dim.Annotative}");
              break;
            default:
              ed.WriteMessage("\nAnnotativeStates.NotApplicable");
              break;
          tr.Commit();
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 5 of 10
jlobo2
@Alexander.Rivilis  I am using a similar code to change the annotative property. But whenever I use it, the dimensions do not show up in the drawing. I am plotting other block attributes as well.
The code, I am using is below:
            using (Transaction acTrans = theDb.TransactionManager.StartTransaction())
                pBlockTbl = acTrans.GetObject(theDb.BlockTableId, OpenMode.ForWrite) as BlockTable;
                pModelSpaceTblRcd = acTrans.GetObject(pBlockTbl[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord;
                //pBlockTbl.Dispose();
                // Prepare dimension
                string tempDimensionTextToPlot =  string.Format("{0:0.00}", (rightDist - leftDist));
                pDimension = new AlignedDimension(
                    new Point3d(leftDist, originElev, 0),
                    new Point3d(rightDist, originElev, 0),
                    new Point3d(leftDist + ((rightDist - leftDist) / 2), originElev + elevDeltaToDimLine, 0),
                    tempDimensionTextToPlot,
                    idDimensionStyleStandard);
                //change
                pDimension.DimensionStyle = idDimensionStyleStandard;
                pDimension.LayerId = idLayerDimension;
                pDimension.Annotative =  AnnotativeStates.True;
                // Add dimension to database
                pModelSpaceTblRcd.AppendEntity(pDimension);
                acTrans.AddNewlyCreatedDBObject(pDimension, true);
                // Finished with this dimension
                //pDimension.Dispose();
                acTrans.Commit();
Message 6 of 10
Alexander.Rivilis
[CommandMethod("CreateDimAnno")]
public void CreateDimAnno()
  Database db = doc.Database;
    BlockTableRecord curSpace =
      tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite) as BlockTableRecord;
    Dimension dim = new AlignedDimension(
                new Point3d(0, 0, 0),
                new Point3d(100, 0, 0),
                new Point3d(50, 20, 0),
                db.Dimstyle);
    dim.SetDatabaseDefaults(db);
    curSpace.AppendEntity(dim);
    try
      dim.AddContext(db.Cannoscale);
    catch { }
    tr.AddNewlyCreatedDBObject(dim, true);
    tr.Commit();
Expert Elite Member
Message 7 of 10
jlobo2
@Alexander.Rivilis
That is simply awesome. That worked great.
How do I know, that I have to append it first and then change the property?
Is there a website or a course I can learn all these things from?
Message 8 of 10
Alexander.Rivilis
@jlobo2 wrote:
@Alexander.Rivilis
Annotation Scales reffer to Database. So you have first add it to Database, and after make it annotative.
Only samples on this forum, other forums and blogs can help you.
In English:
http://adndevblog.typepad.com/autocad/
http://through-the-interface.typepad.com/through_the_interface/
http://www.theswamp.org/index.php?action=forum
In Russian:
http://adn-cis.org/forum/
Expert Elite Member
Message 9 of 10
jlobo2
@Alexander.Rivilis
Can you share some light for the following post please.
Rotate a set of objects along an axis
I would appreciate your help
Message 10 of 10
qnologi
I'm sorry, but code is above my pay grade : (
qnologi
