Is it still true that the AutoCAD NET API does not give access to embedded Excel
oransen
oransen
Is it still true that the AutoCAD NET API does not give access to embedded Excel worksheets?
I've looked and looked and there is some complicated MFC stuff for a linked Excel file but I can find no real help for embedded Excel files.
In code I've got as far as this:
                            foreach (ObjectId id in btr)
                                if (id.ObjectClass.Name == "AcDbOle2Frame")
                                try
                                    Ole2Frame oleFrame = tr.GetObject(id, OpenMode.ForRead) as Ole2Frame;
                                    //object excel = oleFrame.OleObject;
                                    // Excel.Workbook EmbeddedExcel = (Excel.Workbook)oleFrame.OleObject.GetType();
                                    Type eType = oleFrame.OleObject.GetType();
                                    string sMsg = "found OLE object  = " + eType.ToString() ;
                                    LogWriter.LogWrite(sMsg);
                                catch (System.Exception e)
                                    string sMsg = string.Format("Exception ExcelChanger: {0}", e.Message);
                                    System.Windows.Forms.MessageBox.Show(sMsg);
...but any attempt to do anything useful results in a COM HRESULT error.
antonio.leonardo
Hi @oransen,
If you decide to throw consume Excel/Access files as OleDb, you need as a prerequisite to install the connector/driver, it's regardless of the AutoCAD .NET API.
Also, Adam Nagy explains about approch as similar as your shared code.
Att,
Antonio Leonardo
oransen
@antonio.leonardo  thanks for the pointers...
antonio.leonardo
You're welcome!
