How to set default paper size for plotter
gregLNS5D
Message 1 of 12
gregLNS5D
Hello!
I created a new paper size Arch D Landscape to print a 36"x24" sheet to print in landscape view.  Right now I am having to select the paper size every time I print.  What is the easiest way to set a default paper size to where it will save the Arch D Landscape paper size and keep it every time I print.
Greg
Replies (11)
Message 2 of 12
Kent1Cooper
At least within a given drawing, next time you Plot it, get it set as you want, and pick this:
Kent Cooper, AIA
Message 3 of 12
imadHabash
You can use named page setups to store plot settings to publish a drawing. >> Click <<
Imad Habash
Message 4 of 12
gregLNS5D
I read the article, but it does not tell me how to make the plotter automatically default to my Arch D Landscape paper size.  I would think this is a easy solution.  It is a common problem, and should not be complicated.
Message 5 of 12
pendean
Community Legend
Community Legend
@gregLNS5D basic AutoCAD knowledge you might as well get used to right away: PLOT settings are unique to and only saved in each tab in each DWG file. There is no universal "I want this to be my default all the time anytime I plot from any file anywhere in autocad" settings. This old program has never worked like that, still does not.
You can however automate your choices using LISP or button macros in the interface, or if you only want to use the built-in tools you'll have to create a master template file with presets and named pagesetups that you import and use all the time with PSETUPIN command.
How would you like to proceed from here? Lots of folks in this forum can help you navigate these limited options.
Message 6 of 12
cadffm
The is no function like that.
Acad choose the Pagesize related to the previous selected pagesize (Acad tries to choose the pagesesize of your new selected printer which is near to the same size)
Use templates (for new new drawings or new Layouts),
or create a Menumacro to setup the current pagesetup.
Sebastian
Message 7 of 12
dany_rochefort
Message 8 of 12
gregLNS5D
OK.  This may be an oversimplification and granted I am a novice in Autocad when it comes to setting up printers.  I see that every time I open the plot it defaults to paper.  Therefore in my mind there is a default.  Why cant I just change the default from paper to Arch D Landscape.
Message 9 of 12
gregLNS5D
Also I sent a request to Autocad Technical support to find an answer.
Message 10 of 12
pendean
Community Legend
Community Legend
Once more, that depends on which DWG it is you are opening and whom set it up to do that in the first place (same exact rules still apply, either you set it up or Autodesk set it up). "support" is not going to do anymore that what everyone here is asking you to explore and investigate 🙂
@gregLNS5D wrote:
OK.  This may be an oversimplification and granted I am a novice in Autocad...
That's fine, we've all been there, we've all resisted understanding how this program works, but we caught on eventually 🙂
Welcome aboard.
Message 11 of 12
dany_rochefort
@gregLNS5D This is ''Autocad Technical Support'' right here dude. You've been told how to create a page setup in like 7 different ways by mulitple Highly Qualified Indiviuals and you still don't get it...
By the way, you are replying to yourself in all your posts '' gregLNS5D in reply to: gregLNS5D ''. That's not how a chat works, your are supposed to reply to those you a speaking too rather than talking to yourself... Nice talk !  🙄
Message 12 of 12
Kent1Cooper
@dany_rochefort wrote:
...  By the way, you are replying to yourself in all your posts ....
[And just to clarify why that is happening, it comes from using the "Reply to the topic..." slot below the last Message.  Anything posted from there reports as being in Reply to Message 1's author.  Use the REPLY button toward the bottom right of the Message you're replying to, and it will show as being in Reply to the author of that.]
Kent Cooper, AIA
