How to scale two different scaled drawings in one model space to same scale
Message 1 of 14
HI,
I have two different scale drawings which I need to make to one scale and size.
Please advise
Replies (13)
Message 2 of 14
j.palmeL29YX
Maybe the VARIA command will help you.
If not so, some more detailed informations would be appreciated.
cadder
Jürgen Palme
Message 3 of 14
Hi Betreff,
I couldn't find "VARIA" command.
Message 4 of 14
j.palmeL29YX
A big sorry, my mistake. Use the SCALE command. (I had some trouble in my mind).
Excuse again
cadder
Jürgen Palme
Message 5 of 14
Yes I have AutoCAD 2018 version English
Message 6 of 14
Still I am getting as "Unknown Command"
Message 7 of 14
How do we find out the scale of reference object?
Message 8 of 14
j.palmeL29YX
I edited my previous post.
See above ...
Jürgen Palme
Message 9 of 14
Hi Cadder,
SCALE does nt help me because I dont the scale dimensions of first object
Message 10 of 14
j.palmeL29YX
In the attaced sample you see an rectangle with width=3. Assuming its drawn in the correct scale.
Beside another rectangle. Its width should be 5, but it is drawn in a wrong (unknown) scale factor.
Follow the steps in the screencast to solve the problem.
https://autode.sk/2qXinZM
cadder
Jürgen Palme
Message 11 of 14
This sounds like a situation where ALIGN command could help.
Message 12 of 14
Thanks.I will try.
Message 13 of 14
gotphish001
I suggest using the above screencast method and making both objects in models space full scale 1:1. Then use paperspace viewports to scale them to whatever scales you need. This will prevent your issue down the road.
Nick DiPietro
Cad Manager/Monkey
Message 14 of 14
Hi hello Tommace,
Yes you can scale two different scaled drawings in one model space to same scale.
Command: dimstyle and click modify and select Primary Units, then look for for the Scale Factor: and put the value that  you want.
