We are implementing an application, where we are drawing objects, representing a panel, which represents the columns of the wall. I need to rotate the set of objects (the columns) together on one axis.
How do I achieve it?
Expected Result
I have the following code, but it's for rotating each objects.
using (Transaction acTrans = dwgDb.TransactionManager.StartTransaction())
// Access drawing block table
pBlockTbl = acTrans.GetObject(dwgDb.BlockTableId, OpenMode.ForWrite) as BlockTable;
pBlockRef = (BlockReference)acTrans.GetObject(thePANBLKBlockReference, OpenMode.ForWrite);
pBlockRef.ColorIndex = colorIndex;
Point3d tempPoint = pBlockRef.Position;
Matrix3d curUCSMatrix = acDoc.Editor.CurrentUserCoordinateSystem;
CoordinateSystem3d curUCS = curUCSMatrix.CoordinateSystem3d;
// Rotate the polyline 45 degrees, around the Z-axis of the current UCS
pBlockRef.TransformBy(Matrix3d.Rotation(0.7854,
curUCS.Yaxis,
tempPoint));
acTrans.Commit();
