How to rotate set of objects along an axis in AutoCAD?
jlobo2
jlobo2
We are implementing an application, where we are drawing objects, representing a panel, which represents the columns of the wall. I need to rotate the set of objects (the columns) together on one axis.
How do I achieve it?
Expected ResultExpected Result
I have the following code, but it's for rotating each objects.
            using (Transaction acTrans = dwgDb.TransactionManager.StartTransaction())
                // Access drawing block table
                pBlockTbl = acTrans.GetObject(dwgDb.BlockTableId, OpenMode.ForWrite) as BlockTable;
                pBlockRef = (BlockReference)acTrans.GetObject(thePANBLKBlockReference, OpenMode.ForWrite);
                pBlockRef.ColorIndex = colorIndex;
                Point3d tempPoint = pBlockRef.Position;
                Matrix3d curUCSMatrix = acDoc.Editor.CurrentUserCoordinateSystem;
                CoordinateSystem3d curUCS = curUCSMatrix.CoordinateSystem3d;
                // Rotate the polyline 45 degrees, around the Z-axis of the current UCS
                pBlockRef.TransformBy(Matrix3d.Rotation(0.7854,
                                                     curUCS.Yaxis,
                                                     tempPoint));
                acTrans.Commit();
Alexander.Rivilis
You have to set single tempPoint to the value of base point of rotation. It is not a Position of BlockReference in your case.
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Alexander.Rivilis
By the way, why this topic was created in this forum ??? This is not the first time you selected wrong forum.
Expert Elite Member
jlobo2
Got the Output. Thank you @Alexander.Rivilis
Sorry about the forum. Which forum should I use for posting these questions?
Alexander.Rivilis
You should posting such questions to .NET forum: https://forums.autodesk.com/t5/net/bd-p/152
Expert Elite Member
Alexander.Rivilis
Problem was solved now?
Expert Elite Member
jlobo2
Yes @Alexander.Rivilis  Thank You once again.
I will be mindful of posting such questions in the .NET forum henceforth.
