How to rotate model space without losing real coordinates?
I have a drawing that is 8.0788 degrees off true north, and I would like to rotate the model space without losing the original coordinate data. I will be sending this drawing to a surveyor so it needs to stay exactly where it is with all its properties.
I have tried Dview and Twist, which works, EXCEPT that when I go to draw anything (say a rectangle), it's still aligned to the original coordinates of the file.
Does anyone have a solution to this?
Thank you in advance!
imadHabash
Rotate and align your UCSicon to your drawing ( 8.0788 degrees ) or to the angle that you need ....  UCS command >> OBject , now type PLAN command then two enter . now you can continue your work . to get back to your origin angle type UCS command >> World . then PLAN command >> two enter .
Imad Habash
arpansark0544TCX
This is working great. Thank you.
TomBeauford
I added a macro to "Toggle between UCS View & UCS World"
^C^C(if(zerop (getvar 'worlducs))(command-s "UCS" "World")(command-s "UCS" "View"))
 Then added the string
"$(if,$(getvar,worlducs),,$(if,$(getvar,viewdir),$(getvar,ucsname) ,Plan ))"
to MODEMACRO in my acaddoc.lsp file so the current View setting would be displayed on the status bar.
(setvar 'MODEMACRO
    (strcat
         "$(If,$(Eq,$(Getvar,dbmod),0),,* )" 	;The asterisk indicates the drawing has been modified.
;         "$(getvar,cprofile)" 				;Current Profile
;         ", $(getvar,wscurrent)"				;Current Workspace
         "$(getvar,textstyle) "
         "$(rtos, $(*, $(getvar,cannoscalevalue), $(getvar,textsize)), 2, 2) "
         "$(if,$(getvar,worlducs),,$(if,$(getvar,viewdir),$(getvar,ucsname) ,Plan ))" ;Thanks Kent Cooper
         "$(if,$(and,1,$(getvar,pickstyle)),,<Group off> )"
         "$(if,$(and,2,$(getvar,groupdisplaymode)),[Group] )"
         "$(if,$(and,16384,$(getvar,osmode)),,$(if,$(and,1,$(getvar,osmode)),E))"
         "$(if,$(and,16384,$(getvar,osmode)),,$(if,$(and,2,$(getvar,osmode)),M))"
         "$(if,$(and,16384,$(getvar,osmode)),,$(if,$(and,4,$(getvar,osmode)),C))"
         "$(if,$(and,16384,$(getvar,osmode)),,$(if,$(and,8,$(getvar,osmode)),Nod))"
         "$(if,$(and,16384,$(getvar,osmode)),,$(if,$(and,16,$(getvar,osmode)),Q))"
         "$(if,$(and,16384,$(getvar,osmode)),,$(if,$(and,32,$(getvar,osmode)),Int))"
         "$(if,$(and,16384,$(getvar,osmode)),,$(if,$(and,4096,$(getvar,osmode)),Ex))"
         "$(if,$(and,16384,$(getvar,osmode)),,$(if,$(and,64,$(getvar,osmode)),Ins))"
         "$(if,$(and,16384,$(getvar,osmode)),,$(if,$(and,128,$(getvar,osmode)),Per))"
         "$(if,$(and,16384,$(getvar,osmode)),,$(if,$(and,256,$(getvar,osmode)),T))"
         "$(if,$(and,16384,$(getvar,osmode)),,$(if,$(and,512,$(getvar,osmode)),Nea))"
         "$(if,$(and,16384,$(getvar,osmode)),,$(if,$(and,2048,$(getvar,osmode)),A))"
         "$(if,$(and,16384,$(getvar,osmode)),,$(if,$(and,8192,$(getvar,osmode)),Par))"
         "$(if, $(!=, $(getvar,viewtwist), 0), Viewtwist: $(angtos, $(getvar,viewtwist) [, 0, 2]) , )"	;Thanks alanjt
         "$(if, $(!=, $(strlen,$(getvar,refeditname)), 0), Xref = $(getvar,refeditname))"
         "$(If,$(Eq,$(Getvar,PStyleMode),0),STB,CTB )"
         "$(if,$(>, $(getvar,dynmode), 0),$(if,$(=,$(getvar,dynpicoords),0),@,#),#)"	;Dynamic coordinate entry.
         " $(getvar, cmdnames)"
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
