How to return the tracking settings to default
carlos_koo
Observer Observer
Message 1 of 8
carlos_koo
Observer
Observer
My tracking settings seem to have changed and I would like for them to return to normal. I like to use the default angles of 5, 10, 15, 30, 60 and 90.
Replies (7)
Message 2 of 8
paullimapa
On that menu click on Tracking Settings or on the Command prompt enter:
+DSETTINGS 1
Then on the Polar Angle Settings Increment angle drop down list select
Now the increment of 5 is checked:
Paul Li
IT Specialist
@The Office
Message 3 of 8
carlos_koo
Observer
Observer
I followed the steps indicated.
The order of the angles has been fixed, but the increments for each angle haven't.
Thanks in advance.
Message 4 of 8
paullimapa
when you enter at the command prompt POLARANG what does the current value show?
Paul Li
IT Specialist
@The Office
Message 5 of 8
carlos_koo
Observer
Observer
Hello @paullimapa , the current value for POLARANG is 5.
I started autocad today and suddently the angles seem to be correct. Why do you ask? What should the value for POLARANG be?
Message 6 of 8
paullimapa
Selecting 5 on the Settings Increment angle in the Dsettings window actually sets POLARANG when AutoCAD is behaving properly
Paul Li
IT Specialist
@The Office
Message 7 of 8
carlos_koo
Observer
Observer
I see, I don't know what it was but I think the issue was corrected. Thank you for your atenttion and the solution.
Message 8 of 8
paullimapa
Glad that worked out for you…cheers!!!
Paul Li
IT Specialist
@The Office
