How to remove Hatch from multiple text/mtext in various hatch
Message 1 of 11
How can we remove the hatching from multiple texts shortly in Autocad(any shortcut method to do so..)? [a layer having huze No. of text & mtext I want to remove the different different hatchings…in short way…]
Replies (10)
Message 2 of 11
imadHabash
would you please attache here a screenshot for your issue ?
Imad Habash
Message 3 of 11
Alfred.NESWADBA
how did you hatch MTEXT or TEXT objects? I would not know of a way that works (except you have vectors building up characters with geometry like line, arc, polyline, ..)
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 4 of 11
Dear Sir(s) Thanks for replying
I now how to remove the hatch From the text or else but when a drawing is very big then this will very time consuming to select & remove single singe text..
I just want is there any shortcut way to remove all text layer removed from the HATCH
Message 5 of 11
Alfred.NESWADBA
Well, you know it, but I don't know how you hatch a text ... can you please upload a small dwg-file that is showing such a text and hatch.
As long as I don't know what you have I can't tell you how to remove that.
- alfred -
Alfred NESWADBA
Message 6 of 11
imadHabash
>> I now how to remove the hatch From the text ..
But we don't .... because your issue still need an image or a .dwg CAD file to know about what you're talking . !!   🙂
Imad Habash
Message 7 of 11
I have uploaded a sample Drawing
Message 8 of 11
Alfred.NESWADBA
well, thank you for the drawing, makes it clear now that you want to  remove the text from the hatch.
Please watch my video, at least select the hatch and remove the border ...
- alfred -
Alfred NESWADBA
Message 9 of 11
Dear sir thanks for replying me
but you have not got my point
I know both the (select & remove hatching) but I want to Know short cut method to do this for many Nos. of text and Many No. of hatch.
Message 10 of 11
Alfred.NESWADBA
>> of hatch.
AutoCAD can only modify hatch-by-hatch to do that, if you need to run that automatically for multiple hatches in one step you need to find a tool or write a tool that can do that.
Please look into the customization forum >>>click<<< (or place a post, with the drawing + the description) with your question if someone can help you in writing the code.
Sorry to not have a direct solution.
- alfred -
Alfred NESWADBA
Message 11 of 11
imadHabash
as i understand that you want to remove the text background from the hatch area and for many text's , as seen from below image select your needed hatch's and then from properties dialog change Island detection style
Hope that's help ,
Imad Habash
