How to reduce the size of a DWG file in AutoCAD
Detach all unneeded Xref files using Xref command enter the PURGE command and select Purge all. Use SAVEAS to save the file it will reduce the size of the Dwg file.
Chandu Akkani
Senior Design Associate Civil Engineer
Phone: +1-434-406-4864
pendean
Community Legend
Community Legend
>>>.... Use SAVEAS to save the file...<<<
WBLOCK command is the better solution.
