How to reduce the number of faces in Mesh in AutoCAD 3D
rsekarUSRKV
Observer Observer
rsekarUSRKV
Observer
Observer
I am modelling reducer pipe in AutoCAD 3D to Import to analysis software.  Here , i am facing problem in reducing number of faces in mesh.
Please check the attached Snapshot for your reference.
pendean
Community Legend
Community Legend
May I ask, why use a MESH if you don't want a MESH (aka faces)?
Would this tip from Autodesk help with your other program
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-convert-a-b...
leeminardi
There are a host of mesh edting tools discussed here.
A good start might be by using meshmerge found on the Mesh ribbon.
lee.minardi
rsekarUSRKV
Observer
Observer
Thankyou.
I want to analysis a circular pipe for that,  have to prepare 3D model to import to analysis software. Actually in the model I have to Mesh the entire pipe (5m dia pipe and 10m length) equally by 0.5m X 0.5m mesh (Both direction- along length & circumferential).
