AutoCAD Forum
How to reduce ram using AutoCAD2012
8 REPLIES 8
Message 1 of 9
1004 Views, 8 Replies
problem:
when I use Autocad2012 32 bit, it take a lot of Ram even open it with nothing.
Does somebody know how to reduce Ram as less as possible?
you will be appriciated.
problem:
8 REPLIES 8
Message 2 of 9
Alfred.NESWADBA
Alfred.NESWADBA
how much memory does it use when just opened?
And what functionality do you NOT use?
What operating system are you running?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
- alfred -
Alfred NESWADBA
Message 3 of 9
pendean
pendean
Community Legend
Community Legend
32bit Windows? XP? Nothing much you can do except to turn off all background running applications, and set your anti-virus to ignore AutoCAD and all of it's files.
Message 4 of 9
jggerth
in reply to: pendean
jggerth
Dropping back, and asking the basic question -- why do you care how much RAM autocad uses, and why would you want it to use _less_?
Generally speaking, any application will use all the memory it needs to use, and it's much more effective if the application is using RAM instead of swapping to disk constantly.
Message 5 of 9
Bob_Zurunkle
in reply to: jggerth
Bob_Zurunkle
Perhaps OP should search these forums for that treatise called Speed Up AutoCAD?
If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted 🙂
Message 6 of 9
in reply to: Alfred.NESWADBA
about 100M , system Win7 32bit
Message 7 of 9
Actually , I have to open CAD together with PDM system( also take lots of ram), so will slow down the computer, even it's 4G Ram. or have some good way to speed up CAD
Message 8 of 9
Alfred.NESWADBA
Alfred.NESWADBA
from your first post:
from last post:
>> about 100M
Sorry, my Outlook needs 200MB and Firefox 300MB after a few minutes, if you have problems when (nowadays) a software needs 100MB then you have to change to 64bit. For AutoCAD 100MB is really not much (btw. when I start AutoCAD 2012 it uses 350MB)!
- alfred -
Alfred NESWADBA
from last post:
>> about 100M
- alfred -
Alfred NESWADBA
Message 9 of 9
yes, from quantity, it's not so much. But the reason i doubt about that is my computer is slow, and after check all the software, I find CAD take most resource, so I guess maybe it's problem where it is.
And, thank your kindly help all the same.
AutoCAD Inside the Factory
