Dear Peers,
I am a newbie to this community. So please pardon me if questions are simple or for any mistake. I am using Autocad for more than 3 years for furniture industries.
The major reason to come here is that I am stuck at present while designing a furniture using Autocad 2010.
I want to draw a hammered pattern on a metal sheet with round shape on an item using Autocad. I have attached two images to clear my thinking and the similar pattern I want to use on the item. Please find the attachment to see the pattern that I wanted to use in Autocad. So I am not exactly finding the right command in Autocad to draw the hammering pattern on the item.
I would be more than happy to appreciate any suggestion on the same and it would be really kind of you.
Thanking you in advance for your support and time. It matters a lot to me.
Best,
Arvind
Solved by Patchy. Go to Solution.
