What is a good way to plot white entities on top of an image background? We're using a ctb plot file. C3D 2022 Win 10. I'm willing to change the entities, layer or ctb settings.
You should create a 255 color layer to place all the overlayed white entities.
On the CTB's Plot Style Table Editor, find the "Plot Styles" list, scroll-down up to "Color 255", select it and under Properties, make sure that the "Color" value is setted to "Use object color".
what is your problem or which way you using know?
You can set object color to...
Or you can translate a color 1-255 to..
.. color 255,255,255 (it is a truecolor value)
for example.
Sebastian
