How to open an empty drawing (without template)
dvrVSNMW
Message 1 of 9
dvrVSNMW
if I want to open a new empty drawing, a popup always show and asks what template I want.
How can I open a blank drawing?
Replies (8)
Message 2 of 9
cadffm
right of [Open] is a small menu, open it
and you can start a new drawing for metric system, or for imperial/british system.
Sebastian
Message 3 of 9
dvrVSNMW
I think it is not showing with me... ?
Message 4 of 9
cadffm
But I guess you want another thing.
You like to use a template, but you don't like to select a template file every single time, or?
Create your own template, or use the acad.dwt (for imperial) or acadiso.dwt for metric drawings
and set this template as QNEW
Options/Files/Template...... QNEW
And from now QNEW using this template for a new file.
Sebastian
Message 5 of 9
dvrVSNMW
No, 99% of the time I open a template. But for now I need to make some new blocks and I like to start with an empty drawing. But I don't know how...
Message 6 of 9
dvrVSNMW
And I can now 🙂
Ty very much!
Message 7 of 9
pendean
Community Legend
Community Legend
Message 8 of 9
marcel.vandenoosterkamp
ctrl+n and quite fast after that enter opens, without the popup screen, the last used template. Nowadays Autocad is unable to keep up when you work fast so the popup is not showing at all.
This is due to the neverending slowing down after R2004
Message 9 of 9
RSomppi
I think you get the same result if you WBlock from any drawing. AutoCAD automatically uses a "blank" template.
