I did a test with one mtext size and color to another mtext size and color. Both created separately using MTEXT command.
I did a Match Properties and one another and it works.
Now see attached file. Different story on MTEXT made from a QLEADER command.
The Match Properties will not work.
WHY?
No wise guys. How do you fix this so I can match properties on mtext attached to a leader. I do not want to explode the mtext.
Seems to work OK for me using (vanilla) AutoCAD2015
Are all the options checked in MATCHPROP settings?
If still no luck, upload a sample drawing with two different Leaders/Mleaders/Qleaders or whatever you're trying to match.
YES ALL CHECKED.
I'M BRINGING IN ANOTHER DRAWING (S) INTO A DRAWING WORKING FILE TRYING TO MATCH PROPERTIES WITH OTHER TEXT WITH LEADERS TO A NEW TEXT WITH LEADERS. AND NOTHING.
To all Thanks.
This is the solution I found that fixed my problem.
I now can match properties with a multileader mtext with any text.
See attached.
Thanks a lot. I forgot about the mleaderstyle settings. It's been at least 10 years since I ever looked at that for settings.
