How to make existed multileader vertical
Richard_Yankee
Message 1 of 9
Richard_Yankee
I have a lot multileader annotation and i was told to make all the leaders vertical. Is there anyway to make the come true easily, cause i have a lot of annotations. Thanks in advance😀
Replies (8)
Message 2 of 9
pendean
Community Legend
Community Legend
@Richard_Yankee Nothing built-in "automatic" offers that ability except to use object snap tracking which takes some practice to perfect https://www.nobledesktop.com/learn/autocad/object-snap-tracking#:~:text=Object%20Snap%20Tracking%20c...
Message 3 of 9
ВeekeeCZ
Easy with LISP.
http://www.lee-mac.com/runlisp.html
(defun c:Mleader90 ( / s i e d a b)
  (if (setq s (ssget "_:L" '((0 . "MULTILEADER"))))
    (repeat (setq i (sslength s))
      (setq e (ssname s (setq i (1- i)))
	    d (entget e)
	    a (cadr (assoc 110 d))
	    b (cadr (assoc 10 (member '(302 . "LEADER{") d))))
      (setpropertyvalue e "TextLocation/X"
	((if (> b a) - +) (getpropertyvalue e "TextLocation/X") (abs (- b a))))))
  (princ)
Message 4 of 9
Richard_Yankee
Hi @ВeekeeCZ, Thanks for your kindly help, I really appreciate.
I tried the lisp, it seems only works for some of Mleaders not all of them. Could you please help to check what's going on coz  I'm not farmiliar with Lisp. Thank you so muchMleader90.gif
Message 5 of 9
ВeekeeCZ
Yeap, I can see that, thanks. That's all I can do with the picture.
Message 6 of 9
pendean
Community Legend
Community Legend
I'll share one with you too.
Message 7 of 9
ВeekeeCZ
Ok, a different approach does that trick.
(vl-load-com)
(defun c:Mleader90 ( / s i c o)
      (and (setq o (vlax-ename->vla-object (ssname s (setq i (1- i)))))
	   (setq c (vlax-safearray->list (vlax-variant-value (vla-getleaderlinevertices o 0))))
	   (vla-SetLeaderLineVertices o 0 (vlax-safearray-fill (vlax-make-safearray vlax-vbDouble '(0 . 5)) (apply 'list (mapcar '(lambda (x) (nth x c)) '(0 1 2 0 4 5))))))))
  (princ)
To make them flat, change the number series to 0 1 2 3 1 5.
Message 8 of 9
pendean
Community Legend
Community Legend
(vl-load-com)
  (princ)
Both newer versions work great in the sample I shared. Thanks.
Message 9 of 9
Richard_Yankee
Thanks so much
